Hello everyone and sorry that I don’t speak English and I use an online translator.
I activated the free trial of the program, but after answering the first questions of the program, saying width and length of my Sculpfun s9 printer everything seems ok. But when I tell the machine to go to home it does everything perfectly and is positioned at point 0.0, but as I click “Frame” to see where it prints, it gives me the following error:
Il target di movimento del G-code supera la corsa della macchina. La posizione della macchina viene mantenuta in modo sicuro. L’allarme può essere sbloccato. (Fare clic con il pulsante destro del mouse sul pulsante “Dispositivi” per ripristinare la connessione)
Sulla linea o vicino alla linea 0:
Streaming completato in 0:00
[MSG:Ripristina per continuare]
Ok
Grbl 1.1h [‘$’ per aiuto]
[Msg:‘$H’|’ $X’ da sbloccare]
[MSG:Attenzione: Sbloccato]
Ok
What should I do to fix it? I point out that I have also installed the Limit Switches on the machine.
You deleted the other posting while I was answering it. So now you get the short answer. You have a program design issue.
How to take a screenshot
Upload a snapshot No camera please) of the complete Lightburn window with the Cuts and Laser panels visible. Also include a snapshot of the Preview window open with Show traversal moves checked.
Upload a snapshot (no camera please) of the complete Lightburn window with the Cuts and Laser panels visible. Also include a snapshot of the Preview window open with Show traversal moves checked
Ninguna de esas ventanas es lo que pedí. Inténtalo de nuevo.
Sube una instantánea (sin cámara, por favor) de la ventana Lightburn completa con los paneles Cortes y Láser visibles. Incluye también una instantánea de la ventana Vista previa abierta con Mostrar movimientos transversales marcado
Scusa inoltre ho notato che con le coordinate assolute se dico di andare a home, il laser si sposta in basso a sinistra (perfetto), se invece clicco vai all’origine si sposta in alto a destra.
E’ normale?
Home is a machine position, Origin is a project position. Home does not move. Origin can be moved anywhere in the workspace. That one you can control. Stay with Absolute Coords for now and you will find little need to worry about the Origin.
This screen is with the machine at home position? Did you click get position in the move window as well, or is that still the previous value from when you clicked origin?
Perhaps translation error, did the arrow keys operate correctly?
Ti scrivo i passaggi che ho fatto per avere quella foto:
1 con le coordinate assolute ho cliccato posizione originale (il laser si è spostato in basso a sinistra)
2 ho cliccato ottieni posizione e mi ha dato i valori negativi x=-377 e y= -392
3 ho digitato $# su consolle e mi ha tirato fuori tutti quei codici.
Grazie a tutti per la pazienza
ho risolto il problema utilizzando LaserGRBL, ho portando in home il laser e fatto reset punto 0 e mi ha tolto i valori negativi, sistemandomi il codice g92
Ora LightBurn va benissimo.
Sicuramente si poteva fare anche tramite LightBurn, il problema è che non lo conosco.
Ora impiego questo mese di prova per testarlo perché mi sembra fantastico.
Grazie ancora e scusate per il disturbo, sicuramente vi chiederò altri aiuti in futuro.
To explain what was happening, your machine was reporting machine coordinates, not workspace coordinates. To make them agree if this happens again, enter G10 L2 P1 x-377 Y-392 in the Console window.
G92 on non-modal, meaning the controller does not remember it. So you may be back to the same situation as when you started.
