xeriix
(Erick)
June 24, 2019, 9:35pm
1
Hi, I would like to know if you can help me with my problem.
My laser cuts well but at the time of engraving it gives me a few jumps and also leaves me black points in the engraving.
Here I leave the images.
I USE GRBL
http://es.tinypic.com/r/1687equ/9
http://es.tinypic.com/r/2115lbp/9
Rick
(Technical Evangelist)
June 24, 2019, 10:53pm
2
Please start by sharing your GRBL setup values by sending $$ in Console and pasting the response series (such as $0 to $132) back here.
Also, we would like to see a full screenshot of your LightBurn Window, and one of the Edit → Device Settings Window. No cell phone pics, please.
xeriix
(Erick)
June 24, 2019, 11:25pm
4
|$0|Step pulse time|10|
|$1|Step idle delay|25|
|$2|Step pulse invert|0|
|$3|Step direction invert|3|
|$4|Invert step enable pin|0|
|$5|Invert limit pins|0|
|$6|Invert probe pin|0|
|$10|Status report options|3|
|$11|Junction deviation|0.010|
|$12|Arc tolerance|0.002|
|$13|Report in inches|0|
|$20|Soft limits enable|0|
|$21|Hard limits enable|0|
|$22|Homing cycle enable|1|
|$23|Homing direction invert|2|
|$24|Homing locate feed rate|5000.000|
|$25|Homing search seek rate|5000.000|
|$26|Homing switch debounce delay|250|
|$27|Homing switch pull-off distance|1.000|
|$30|Maximum spindle speed|1000|
|$31|Minimum spindle speed|0|
|$32|Laser-mode enable|1|
|$100|X-axis travel resolution|80.250|
|$101|Y-axis travel resolution|100.250|
|$102|Z-axis travel resolution|250.000|
|$110|X-axis maximum rate|5000.000|
|$111|Y-axis maximum rate|5000.000|
|$112|Z-axis maximum rate|500.000|
|$120|X-axis acceleration|2000.000|
|$121|Y-axis acceleration|2000.000|
|$122|Z-axis acceleration|10.000|
|$130|X-axis maximum travel|670.000|
|$131|Y-axis maximum travel|1200.000|
|$132|Z-axis maximum travel|200.000|
http://es.tinypic.com/r/2vdk8s9/9
http://es.tinypic.com/r/5ydizl/9
Rick
June 24, 2019, 11:34pm
6
And this, please?
Additionally, I edited your post to include the images within the post for ease. You can paste an image into your posts, so external links are not required.
system
(system)
Closed
July 9, 2019, 12:22am
8
