problem with filling
hello everyone,
my sculpfun s9 has a problem with filling shapes.
when i use the fill option, lines are placed that are not next to each other but about 1mm apart. That is no longer fill.
is that a setting in the software or is there something else? and what can i do to get a normal fill?
Open CUT/LAYERS and try increasing your LPI.
Sorry, does not help at all
my settings are:
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=250.000
$110=6000.000
$111=6000.000
$112=1000.000
$120=1000.000
$121=1000.000
$122=10.000
$130=410.000
$131=400.000
$132=200.000
Your settings look ok, though the LPI is now too high. The native value for the S9 is 318 DPI / 0.08mm line width.
Your speed is somehow too high for the S9, you should not exceed 2000-3000 mm/min with the mechanics of the S9. Do you use the original mainbaord?
Go through this guide to check if you experience any mechanical issue:
Thanx a lot, problem solved…
