Made several tiles using Jarvis stucki and others, was trying to use grayscale to do a white tile painted black, but no matter if u turned negative image on or off it still tried to do it as negative image, swapped to stucki, works fine, any idea what I’m doing wrong or is this normal for grayscale?
Are you setting negative image in the adjust image dialog or in the preview window?
In the cutting settings editor where I adjust speed and power settings
Ok, that’s the same as checking it in the Adjust Image dialog. Did it actually burn as negative when it was not checked or just appeared that way in preview. I have found that the preview window doesn’t always act the way I want it to when dealing with inverted images.
