Hello, I’ve never had a problem with lightburn and fusion before but now when I try to import a dxf file in lightburn it splits up the whole file into small pieces, I’ve tried updating it to newest version, even the beta version but it still happens every time.
If I’m creating a design in F360 and its intended for LB I usually create a drawing from the model, export as a DXF then import that into LB. From your screenshot I’m guessing you’re exporting the DXF directly from the model so although my workflow is an extra step it might solve your issue for the time being.
Well thank you, that works at least, just a bit irritating that I need to do that extra step all of a sudden
