Lightburn uses 0 - 100% for laser power control but GRBL uses 0 - 1000 for power control, consequently when I set power on LB at 100(%) my Atomstack A5 M50 Pro reads the 100 and only sets the power output to 10%. Anyone know a work around or solution?
The scale setting $30=1000 should be set identical to S-value max in the Device Settings. Click Edit and you’ll find Device Settings toward the bottom of the list.
The percentages are automatically calculated based on these two numbers being equal. When these numbers don’t match we see some pretty interesting results.
Thank you very much - have now purchased Lightburn.
This topic was automatically closed after 60 minutes. New replies are no longer allowed.
