Hello! I have a problem that brings me down the path of bitterness, I have an 80w laser with a topwisdom TL-410C controller, the fact is that I want it to start engraving from the point of origin, and when it is going to start, it moves down and start recording backwards, from the bottom to up, is there any way (I already touched all the options) to change this and start engraving from the top to down?
Thank you!
Engraving is bottom-up by default because most machines exhaust in the rear, and pulling smoke across a fresh engraving can make the engraving harder to clean.
In the settings for the engraving layer, change the Scan Angle from 0 to 180 degrees to make it run the other way.
It works!! thanks soooo much!!
