I have an ORTUR Laser Master with a NEJE 20 watt laser.
The device works perfectly.
Now I’ve bought the ORTUR Rotary Roller. I activated the Rotary Roller in Lightburn, deactivated “Soft Limits” and “Homing Cycle” in the machine settings and made and tested the necessary settings under “Set up Rotary”.
During the first test it turned out that everything was burned the wrong way round.
I’ve scanned the whole network to find clues about this bug.
Unfortunately without success.
I am sending four pictures with the settings and the burning process.
Turn the rotary around 180° so the drive is at the other end.
Use the mirror setting on the rotary setup screen.
