When using square array the distance between columns is what i set + 13mm?? for each column. If i set it at 1 it copies at 14 but tells me it is 27. Rows are fine. Am i missing a setting?
Perhaps you have selected Padding between edges
rather than Distance from center to center
Source: been there, done that.
Spot on. Not noticed padding before. Thank you ednisley
