Hello, I created something with Incscape and wanted to laser it. Unfortunately, the message comes that 2 forms are filled but not closed. However, I don’t see where that should be. Maybe someone has an idea?
With your graphic selected, try going to ‘Edit’ > ‘Close Path’. If that doesn’t work, try ‘Edit’ > ‘Auto-Join Selected Shapes’.
Thanks for the answer. Unfortunately the first one didn’t work and the second one can’t be selected…
Please upload your file here so I can take a closer look. If you’re not comfortable sharing it here you can send it to support@lightburnsoftware.com
Logo-GemoART.lbrn2 (38.2 KB)
Try this.
I didn’t have that font, so it may have changed.
I couldn’t close the shape, so I did an outward offset, deleted the original, then did an inward offset the same distance and deleted the outer offset.
Logo-GemoART.lbrn2 (42.8 KB)
Your design has an extra line segment hidden here (you need to pull a node out to see it):
If you delete that, then go to ‘Arrange’ > ‘Break Apart’, then select all of the resulting constituent line segments, and then go to ‘Edit’ > ‘Auto-join selected shapes’, it will connect properly, and become closed.
Good catch. Never realized that was an extra node.
Thank you for your help.
This is a really very good forum
Have a nice day everyone
One additional hint - These larger green squares represent the start / end points of a vector path shape. If there is more than one of them in an object, it means you have two objects, and those are the start/end points of each:
