AMS-Laser
(Eduardo Enriquez)
March 1, 2022, 1:06am
1
Hello, i found a possible bug in Lightburn V1.0.06 if i set my tabs to be auto generated 3 tabs per shape, tab lenght 0.6mm these are cut ok, but if i set to 0.75mm tab size, tabs are not cut, (shape cut completely and continuosly)
attached settings taht worked, only change is tab size to 0.7 or 0.75 and no tabs are cut
Rick
(Technical Evangelist)
March 1, 2022, 1:16am
2
Please show the âPreviewâ window zoomed to a single shape, showing the tabs for that shape. If willing, post the file as well, so we can take a closer look.
As the guy who wrote this feature, I can further confirm: We will absolutely need the project file you are working with.
Sometimes the math just gets weird and unfortunately the only way weâll be able to reproduce this and figure out whatâs up is to have that project file.
Feel free to send it to support@lightburnsoftware.com if you canât share it publicly.
AMS-Laser
(Eduardo Enriquez)
March 1, 2022, 3:56am
4
Can you confirm that you had this issue with every shape when you did this?
I checked the g-code for a single T letter in the 4th file. And this seems to work fine.
; Layer C00
G1X34.519S200F6000
G0X0.75 -- TAB HERE
G1X8.294
G1Y-10.617
G1X6.938
G1Y25.849
G0Y0.75 -- TAB HERE
G1Y1.573
G1X-6.938
G1Y-10.206
G1X-32.982
G0X-0.75 -- TAB HERE
G1X-9.831
G1Y-7.349
AMS-Laser
(Eduardo Enriquez)
March 1, 2022, 4:24am
6
just select every item and generate gcode , it then wont generate tabs, attached the gcode for sheet 1
letras gravograph 1.txt (758.1 KB)
I was finally able to reproduce the issue.
Oddly I couldnât recreate the situation with anything but the same sheet 1. I had to expand my workspace to accommodate the whole thing. The other files worked fine and subsets seemed to work okay.
There must be something with either the number or specific arrangement thatâs causing the issue. Preview looked correct.
AMS-Laser
(Eduardo Enriquez)
March 2, 2022, 3:07pm
8
have a hint, looks like if you give enought time to âfinishâ what ever procesing its being done, it wil work, so mabe a flag to not alow job to be sent until calculations are finished would be a solution, this will explayn why on the other sheets you could not recreate the problem (my computer being slower than yours LoL) and whi with less vectors there is no issue
Ed.
Iâll confirm later tonight if I can reproduce.
[EDIT] - I let it sit to âprocessâ for over 15 minutes with no change. Couldnât get the tabs to appear in the gcode.
AMS-Laser:
This doesnât make any sense to me⌠it doesnât send the job until itâs done calculating everything, including tab placement. Can you further explain what you mean? Step by step.
Update: I actually got it to crash loading up all those tabs - so I think I might get what you are seeing nowâŚ
Are you running the 32 or 64 bit install of LightBurn?
When I reproduced the issue it never crashed.
On W11 64-bit with 16 GB RAM.
I could only get the issue to appear on one file. The bottom-most one as it appears in the post.
This may sound silly but can you send the actual lbrn2 project file, not just the svg?
Working on debugging it and that might help rule things out.
AMS-Laser
(Eduardo Enriquez)
March 3, 2022, 6:47pm
13
AMS-Laser
(Eduardo Enriquez)
March 3, 2022, 6:48pm
14
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
dont know if this helps (support data)
From what I can see I can no longer reproduce this after upgrading to v1.1.00.
There are a couple definite issues weâve found. Adam is cleaning this up now, and we should be able to include this with the patch in a day or two.
AMS-Laser
(Eduardo Enriquez)
March 3, 2022, 9:19pm
18
thanks, no luck for version 1.1.00
i will ask one of my customers to test on this new version
If only there was some way you could renew your license and get the updateâŚ
Iâve just committed a fix for what Iâm pretty sure was causing this. As @LightBurn noted, it should be in the next patch release.
