Problem with the option cut selected graphics
When I select the option to cut selected graphics, it does not respect the point of origin, it takes a tour and later begins to cut from the other side, is there any way to solve this?
Greetings!
I’m sorry, but I really don’t understand what you mean by this - can you describe with a little bit more detail?
Yes, sorry!
Using the option to cut the selected graphics, I send the design to the machine, but it sends it with error since it should start in the place where the green arrow is cut, but it is not, it begins to cut where the red arrow is, That only happens if I select the option to cut the selected graphics, if I deactivate it, everything goes well and I respect the point where I should start, I send photos to make myself understood, thank you!!
Check the ‘Use Selection Origin’ button just below ‘Cut Selected Graphics’.
https://lightburnsoftware.github.io/NewDocs/LaserWindow.html#cut-selected-graphics
The default behavior works the way it does so that if you cut the whole file, but one shape doesn’t cut through, you can just select that one shape and re-run the job, and it will end up in the same place.
Thanks, I’ll try it like this, greetings!
