Problemas con las lineas de avance (Problems with the lines of advance)
Muy buen dia, estimado
la experiencia al utilizar si programa a sido excelente hasta hoy
he querido cortar un archivo con el que anterioridad habia trabajado bien,
mi maquina es una SCULPFUN 9
la LIGHTBURN version 1.4.00
el problema es que el laser deja marcadas unas lineas de trayecto,
ya probe a cambiar $32 en verdadero y sigo con el problema.
Very good day, dear
the experience using the program has been excellent until today
I wanted to cut a file that previously had worked fine,
my machine is a SCULPFUN 9
the LIGHTBURN version 1.4.00
The problem is that the laser leaves some path lines marked,
I already tried to change $32 to true and I still have the problem.
If you have inadvertently selected GRBL-M3 it may not be switching the traverse power off.
With LightBurn up and running, click File, click Save GCode and save this file somewhere easy to find.
Change the filename so it ends with .txt
Open the file in Notepad, and copy the first 10 to 15 lines and paste them into a reply here.
