Hola, tengo un problema con mi S9 y es que al hacer rellenos me salen lineas verticales como si fuera un codigo de barras y no se como hacer que desaparezcan.
Hello, I have a problem with my S9 and it is that when I fill in I get vertical lines as if it were a barcode and I don’t know how to make them disappear.
Next, speeds above 3000 are already critical with the mechanics of the S9. If you want to have high-quality images, use speeds around 2000-3000mm/min, not faster. You can go faster, but you will need to carefully adjust the mechanics and the settings.
The material will have another influence. Wood sometimes has an internal structure that gets exaggerated by the laser process.
Finally, I’d recommend to use a scan angle of 45°, which will decrease the influence of a single axis to the result.
Hola a todos, creo que he dado con el fallo, haciendo pruebas me he dado cuenta que el motor del eje X suena mucho y creo que ahí puede estar el error.
Cambiaré el motor y pondré aquí los resultados.
No puedo enviar aquí en el foro un video del sonido que hace, pero es un sonido, check, check, check, check,
Hello everyone, I think I have found the error, doing tests I have realized that the X axis motor sounds a lot and I think that the error may be there.
I’ll change the motor and post the results here.
I can’t post a video of the sound it makes here on the forum, but it’s a sound, check, check, check, check,
