Probleme de positionnement lors du cadrage
Depuis la validation de ma licence, dès que je lance un cadrage pour voir comment positionner ma pièce, le laser part sur la gauche et se bloque en butée. impossible de laser un gravage.
à la mise en route, voici ce que j’ai dans la console.
ok
[G54:-410.000,32.000,-78.000,0.000]
[G55:0.000,0.000,0.000,0.000]
[G56:0.000,0.000,0.000,0.000]
[G57:0.000,0.000,0.000,0.000]
[G58:0.000,0.000,0.000,0.000]
[G59:0.000,0.000,0.000,0.000]
[G28:0.000,0.000,0.000,0.000]
[G30:0.000,0.000,0.000,0.000]
[G92:0.000,0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000,0.000:0]
Je trouve étonnant que la valeur G54 ne soit pas à zéro.. et je ne sais pas comment modifier cette valeur.
Merci d’avance pour votre réponse.
In the Console window: G54 X0 Y0 Z0
If that does not work: G10 L2 P1 X0 Y0 Z0
Depuis la validation de ma licence ??, dès que je lance un cadrage pour voir comment positionner ma pièce, le laser part sur la gauche et se bloque en butée. impossible de lancer un gravage.
ok
[TLO:0.000]
Thanks Mikeyh, but do I type this command in the Windows console or in the Lightburn software? In the Windows console, it tells me that the G54 command is not recognized.
You talk to the controller board using the Lightburn Console window. At the bottom, there is an input box.
Yes, thank you, I found it.
Thanks for your help.
Let us know if it solves your problem.
Oui, cela à resolu mon probleme.
Merci
