sia se compilo il .gc e eseguo da sd, sia che lancio l’incisione direttamente dal mio pc, il programma comanda i movimenti degli assi x e y, ma non comanda ne la potenza del laser ne la velocità di incisione,
Il laser con file compilati da altri programmi funziona.
LASER RAY5 10W LONGER
Lenovo chromebook con linux penguin
qualcuno ha soluzioni?
NicholasL
(Nicholas Leqeta)
February 2, 2024, 10:33am
2
Alex1982x:
whether I compile the .gc and run from SD, or launch the engraving directly from my PC, the program controls the movements of the x and y axes, but does not control either the laser power or the engraving speed,
Laser with files compiled by other programs works.
Lenovo Chromebook with Linux Penguin
anyone have solutions?
In LightBurn, create a simple line, with a speed and power and use the ‘Save GCode’ button to save the .gc
Do the same in the other program that works.
Open and compare both GCode files using a text editor;
Are the ‘S’ power settings and the ‘F’ feedrates the same in both files?
Example:
; LightBurn 1.4.05
; GRBL device profile, absolute coords
; Bounds: X30 Y30 to X80 Y30
G00 G17 G40 G21 G54
G90
M4
; Cut @ 6000 mm/min, 20% power
M8
G0 X30Y30
; Layer C00
G1 X80S200F6000
M9
G1 S0
M5
G90
; return to user-defined finish pos
G0 X0 Y0
M2
system
(system)
Closed
March 3, 2024, 10:34am
3
