First off , thank you so much for a fantastic software , bought my licenses after testing for 3 minutes
I’m using the Lightburn on my china laser 3018 pro as im waiting for my co2 running Ruida.
since the last upgrade the laser isn’t so easy to use anymore , it seems lightburn send some 'gcode in the startup.
Waiting for connection…
Port opened, waiting for response.
This in turn starts my Z axes down and starts the laser !! the maschine don’t respond to any commands in this state.
What i have found that helps sometimes is to start the lightburn software some minutes before i turn on the laser and attach the cables.
Do you have a “Baud Rate” setting in the device settings? If so, check what it’s set to - the standard is 115,200, but it’s possible your machine either wants something else, or isn’t set to that.
The baud rate was set to 115,200 and it is the hz i use if i connect it to Laser Grbl .
Still stuck in the hospital so not able to read of the maschine settings , but it was flashed about 4 months ago with whatever was the newest at the time.
LightBurn doesn’t send anything on startup (aside from a couple of “enter” keypresses, to get the laser to respond). Check to make sure you don’t have anything like a loose electrical connection or cable, as that could cause this too.
