Problems after updating to latest version
Since I got the latest update some things are doing some strange things.
I wanted to cut a single line. I use an ortur LM3. The laser just did a short burst and then got an power supply error. Tried a few times and always the same issue. Then I switched to my ortur LM2 as I thought I would have to get a new power supply for my LM3.
When I wanted to do the same job with my LM2 it started but it was lasering the line as single dots switching on and off for the whole lenght of the line.
Then I tested with some other shapes and some text and then the laser wanted to do the line as it should be. To cut the line I have to draw a square and put the line next to it. then set the square on an other layer and not active and then the line was done good.
I then tried this “solution” with my LM3 and there was no more power supply error and the line was OK.
Remove the square again problems.
What could be the cause?
Thanks
