I want to draw a straight line between these half circles, but every time I try it goes to a curved line instead of straight across. What am I doing wrong?
Don’t drag to start the line. Click on the start point and release the button.
That is what I was doing, but its not working. I click and release the button before moving the mouse. Also as soon as I click and release the button you can see a little line pop up above the piece before I even have a chance to move the mouse. Strange.
Hover over where I want line to start
Left click where I want to start and a short line pops up above the cursor
Then releasing the button and moving to the right shows this
Here is a link to the file Flag Case template.lbrn2 - Google Drive
if that helps LightBurn ver 1.4.00
I just downloaded the previous version and it is working correctly now. v 1.3.01
Yay, I guess I will use this version until the next one comes out. Thanks
I believe what you’re experiencing is described and somewhat resolved in this Topic.
Long story short, if extending an existing curve LightBurn will use a curve. If extending a line LightBurn will use a line. You can convert the curve to a line after connecting or use other methods to get around this.
You can draw a rectangle and overlay the correct sized circles and then use BOOLEAN subtract A-B - done here in solid fill to make it easier to see
select back ground
ctrl-select circles
UseBoolean Subtract
results
