Problems with adjusting laser efect
Can anyone tell me how to adjust laser effect when engraving/cutting
Imagine the sun through a magnifying glass.The faster you move, the less heat in one spot. The more out of focus, the less heat in one spot. The laser has two modes, off and burn. Vary the speed and %power to contol the burn.
I am guessing this did not answer your question. Before a reasonable answer can be given, you need to provide this information:
  1. What is the output power of your laser (like 5w, 10w, etc.)?
  2. What material are you trying to use under the laser?
  3. What are you trying to do with the laser?
  4. Does the laser behave as expected (Home, Jog, etc.) when using Lightburn?
I have included a jump-start video that might help.
