Problems with AtomStack A10 Pro
Hello,
I got my Atomstack A10 Pro today and set it up.
Unfortunately, I have a problem when using Lightburn.
When I want to engrave a circle, it is not a line but a jagged line, so it is as if the two axes do not work synchronously.
When using LaserGRBL this problem does not exist and the laser works cleanly.
Is it possible that I have to change a setting in Lightburn?
Thanks for your help.
Regards Dominik
You might want to post your ‘cut settings’ that you are using for this, could it be that you are trying to burn too fast, causing mechanical problems
