Hello i recently buy this product but i have some complications with it https://www.amazon.com/-/es/CREALITY-cortador-oficial-impresora-mejorado/dp/B0BQQLHMSK/ref=pd_cart_vw_crc_sccl_1_1/139-0032646-4825671?pd_rd_w=x8eAR&content-id=amzn1.sym.75873c58-c777-4e96-9e4c-71edd776d2ed&pf_rd_p=75873c58-c777-4e96-9e4c-71edd776d2ed&pf_rd_r=0NRKDJ9CGEQHPSVGWBF4&pd_rd_wg=N9DgV&pd_rd_r=6255c15a-16fe-41ca-8345-11ec0ad5459f&pd_rd_i=B0BQQLHMSK&psc=1
Notes:
It’s connected to a CR-10 S5 (500mmX500mm)
I’ve tried changing the usb cable, using a different OS, even using a different computer.
tried to change some of the values ($) in the console on the program of LightBurn but still nothing.
Check the wires many times to check any failure but still nothing happens. change to the FDM of the printer and everything works fine.
Tried to fix the steps in both axis
I’m not a programmer, only a simple entrepreneur with a bunch of knowledge of 3D printing.
So basically I follow all the installation instructions, upload the new firmware but I have a huge problem with the Y axis, let me try to elaborate.
when i send home the printer, the X axis moves correctly but the Y axis starts to move around like forward and backwards really fast, but doesn’t move all the way either, so to stop this irrational move i have to move the bed to the limit switch and stops the command, then i get alarm:8 and Alarm:3.
I’ll send you guys the info of the console so you can help me. I imagined that being the printer and the laser from the same brand, would be even easier to make the laser work but there is definitely something wrong with my configuration. Thanks for your help.
Waiting for connection…
[VER:CV-30.V3.0.24.20221012]
ue:1023.000000
Grbl 1.3a [‘$’ for help]
[0;32mI (27803) serial: Line state changed! dtr:1, rst:1 [0m
ok
ok
[0;31mE (35075) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first [0m
[0;31mE (35076) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first [0m
ALARM:8
Homing fail. Cycle failed to clear limit switch when pulling off. Try increasing pull-off setting or check wiring.
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
[0;31mE (55812) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first [0m
[0;31mE (55814) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first [0m
[0;31mE (55815) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first [0m
[0;31mE (55816) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first [0m
spindle_pwm_off_value:0.000000 spindle_pwm_min_value:0.000000 spindle_pwm_max_value:1023.000000
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
$0=10
$1=25
$2=2
$3=0
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=0
$24=25.000
$25=500.000
$26=250
$27=15.000
$30=1000.000
$31=1.000
$32=0
$100=80.000
$101=80.000
$110=500.000
$111=500.000
$120=10.000
$121=10.000
$130=495.000
$131=495.000
ok
