Greetings to all, I turn to you because I think I have a serious problem with the laser.
On Friday of this week I was doing some engraving tests with the CNC laser machine, without any problem. The next day, I turned on the machine, but something was not right, the signal indicator (green) was on for a few seconds and turned off. Only the red indicator corresponding to the power on continuously turns on, the fans also turn on and the laser guide.
Verify that the connections were solid on the drive adapter board, as well as on the controller card (MKS-DLC32). I did not find any apparent false contact.
I used lightburn as software and verified that the motors responded to the movement indication and moved normally.
I am very new to the topic of cnc and laser cutting. I’ve really run out of ideas of what could happen with my machine.
I hope you can take some time to help me with this problem.
I appreciate your comments in advance.
