Here is the current log after starting the laser. I put the origin at absolute coords, framed the image then moved it to another position. Framed again then went to home position. I then jogged the laser to the centre of the frame (x 200,y 200) and set user origin. It framed correctly but when I move the image to another position it still frames in the original position.
Also after using absolute coords and framing the image is just moves to the bottom left corner of the image, not back to the origin.
Waiting for connection…
ok
[VER:1.1h.2022011001:]
[OPT:VZ,15,128]
Target buffer size found
ok
Homing
ok
ok
[OPT:VZ,15,128]
ok
Homing
ok
<Idle|MPos:0.989,0.996,0.000|FS:0,0|Pn:P|Ov:100,100,100>
ok
Starting stream
Stream completed in 0:10
<Idle|MPos:164.997,164.999,0.000|FS:0,0|Pn:P|Ov:100,100,100>
ok
Starting stream
Stream completed in 0:09
ok
ok
ok
<Idle|MPos:0.989,0.996,0.000|FS:0,0|Pn:P>
ok
Starting stream
Stream completed in 0:11
ok
Starting stream
[MSG:Program End]
Stream completed in 0:08
<Idle|MPos:199.999,199.999,0.000|FS:0,0|Pn:P|WCO:0.000,0.000,0.000>
ok
ok
ok
Starting stream
[MSG:Program End]
ok
<Idle|MPos:199.999,199.999,0.000|FS:0,0|Pn:P|Ov:100,100,100>
ok
Starting stream
ok
ok
ok
Starting stream
