Would any of y’all help me out my machine stops mid run on the the screen stills shows it as actively working but then when I stop and try to regime it does not move. Any help would be greatly appreciated
Is your computer configured to go to sleep after 10 minutes?
If not that, make sure that your USB ports are not configured to power down for power savings.
Two most common causes of laser stopping is USB comms fail - turn off every sleep option you can find for when NOT running on Battery, the other is exceeding work space, usually overscan due speed being used.
