Project change’s intensity at will when engraving pictures
I’ve done all the troubleshooting and suggested tasks google and general maintenance. When I engrave photos on leather. The project will slow down and change intensity of the burn. Creating a distinct line and will do that for and inch or so of the picture then go back to the original intensity. Doesn’t always do it, sometimes I can get one to burn correctly. I’ve only got one line called for. 6000 mm/ 75% has been working like a dream. Nothing changed accept the situation above???
If the problem happens randomly, even on the same image, perhaps Windows goes through one of its mysterious spasms where it’s so busy doing something inscrutable that it doesn’t bother sending data to the laser for a while, thus starving the machine of instructions.
However, if the problem dependably happens at the same place in the same image with the same settings, then it’s likely due to something else.
Protip: Use cardboard rather than leather while you’re testing, until you’re certain it’s working dependably.
