This project stops in the same spot every time. Any ideas as to why?
What does the preview look like?
Do you have the number of passes on each of the cut settings set to at least one?
Try flipping the output checkbox on each of these in turn and then review the preview to see if anything changes.
Might it be related to the positioning of the work? An in maybe it is out of bounds of where the laser can travel. Some details about your machine model and setup would be helpful.
Another thing to try is to verify with the frame button to determine if what Lightburn is going to do is within the work envelope.
- Does it say anything in the console when it stops?
- Does the machine home itself when it stops?
