Project Framing
So I’m having trouble lining up my material borders without a visual laser dot to frame it. I’m curious if there is a way keep the manual fire button enabled during job framing? If not, what are some good tips to ensure that a project will be correctly lined up on the material?
2 options:
  1. Hold the Shift key as you cilck the frame button to enable laser light.
  2. In recent versions you can set up the device to fire while framing
In both cases you must enable “Enable laser fire button” in Edit->Device Settings. A sub-setting of “Laser on when framing” will enable when framing if you’re using a later version.
