Are you saying that the final burned dimensions are 30x bigger than the designed dimensions within LightBurn? If so, you can calibrate your axes in Edit->Machine Settings->Calibrate Axis
This is typically caused by a misconfigured Origin setting in Edit->Device Settings. Your machine is likely meant to be set to front-left.
You are using mm and outputting inches, make sure all setting are consistant in either mm or inches. The mirror image is usually from incorrectly set origin.
Thank you - I did check and everything is in MM. I remeasured my area and made sure the work space was the correct size and the offset as well. I am new at this and very confused.
Thank you - checked what you suggested
I tried to calibrate the axes - but the window asks for a requested distance and an actual distance - I am not sure what to put in here…
they both read 200 currently
I was curious about this setting. If set to 1 the controller will report in inches. That’s not the case here so you should be good to go in that regard.
These define the number of steps per mm of travel for X, Y, and Z respectively. Typically X and Y are the same assuming you have the same stepper driver and motor. Are you getting twice as much travel on X as Y?
