Project stops working after 1 minute
I have a tenhigh 60w laser. COhesion3d smoothie board.
The projects, regardless of material used or type of project (engrave or cut) stop after about a min.
Lightburn timer still going, Lightburn shows machine as busy. Lightburn and machine must be restarted to get rid of the “busy” message
I have tried different cables into my windows laptop
The card is mounted with metal screws into the space in the machine, I had to cut holes in the machine to make room for usb and power cable and the 2 reset tabs (I think they are reset tabs) next to the usb plug
Any suggestions?
Your C3D board may be having issues with static electricity or high voltage causing errors - I found this thread on the C3D forum that may help you https://forum.cohesion3d.com/t/random-stops/4045/3
Please take a look at the Console in LightBurn (Window > Console) to see if there are any errors appearing, let us know if there are.
I will take a look, THanks!
