Purchased a used set up with “no issues”. IT is an Ortur Laser Master 2 Pro but has a Laser Tree LT-80W-AA-Pro laser.
Running a project and it keeps stopping at the same spot. First time using a laser… it shouldn’t be this hard lol
Error Message: error:9
G-code locked out during alarm or jog state.
On or near line 0:
Job halted
Be prepared for a steep learning curve. Laser are not only very dangerous if not handled correctly, usage and settings require LOADS of trial and error and experience. So don’t give up, go on learning and you will get there. But it might take some days and weeks until you are satisfied.
Show the LB screen including the layer and laser window. Those provide valuable insight for diagnosis.
Those settings look ok so far. The only thing that I see is that the port is set to Auto instead of a specific COM port. And you might add your layer settings, maybe those are too high.
Thanks. It’s happening when it’s traveling across the work space to complete a section on the far side of the board. The unit isn’t secured to the table. I’m wondering if the speed it’s traveling is jarring the machine slightly. Gonna try reducing the sensitivity and securing the machine down.
