Projects burning larger than size
My projects are burning larger than than the size I indicated in my file. Example if I set the size to 4inches x 4 inches, the project burns at 4x15
Do you possibly have Rotary enabled?
No i don’t
Can you run this in Console and return output?
We’re looking specifically for $100, $101 values. These are typically meant to be the same. If we see that $131 is roughly 3.75x the value of $100 then that explains the discrepancy.
$100 is 158.098
$101 is 80.000
$131 is 400 000
Are these numbers correct?
I am new to laser Engraving so could you please check the numbers i sent you and tell me what to do next
$100 is 158.098
$101 is 80.000
$131 is 400 000
Can you confirm that the dimensiones you mentioned earlier of 4x15 was width (X) by height (Y)? The $100, $101 values would have me believe that this could where the longer dimension was actually along the X axis. But please confirm.
Also, assuming $100 and $101 values should be the same for your laser, it would seem that the Y dimensions should be burning 2x more than the Y dimension, not 3.75x. Can you reconfirm the original dimensions?
Size i had set is 4 inch x 4 inch. Was burning 4x15. $100 is 158.098
$101 is 80.000
$131 is 400 000
This is what I’d like you to confirm. Is the 15 inches the width or height (X vs Y)? Based on what I’m seeing I would expect this possibly to be along the X. But the way you’ve listed is implying the opposite.
And to confirm, the 15 inches is measured or estimated?
Lastly, you keep providing the $131 value. Is there a specific reason why? I’m wondering if I’m missing something.
15 is the width
You brought up $131 in the beginning
Indeed I did. That was a mistake. I meant to say if $101 was 3.75x $100.
Okay. That makes more sense but doesn’t account for the whole difference.
In either case, let’s adjust and see where that leaves us.
Enter this in Console:
$100=80
Power cycle the laser and then retest your 4x4" square.
That was it, thank you so much
Glad that resolved it. I don’t understand the measured dimension as you stated but as long as it’s working that should be fine.
