Hello Folks! I an trying to cut through a 1/8 inch thick birch plywood for a cut out. I have a Genmitsu 4040Pro with a 10W Laser, What are the proper settings to get this pice cut out? Thank You!
Here’s the material reference chart from Sain Smart for 10 watt.
Hope this helps.
I will give it a try and let you know! Many Thanks!
With air assist and 10w, I cut thru 3mm ply using 700mm/m, 70% power, and 3-5 passes (depends on the wood).
