Prusa: specific requirements on M106/M107 and incorrect M114 reading
Hi, I am a new user and tinkered around for a few days with different SW-packages, I must say I love Lightburn as of now. Unfortunately I have problems getting it to fully work with my retrofitted Prusa MK3S+ :frowning:
The Problem: the Prusa firmware spins the fan (and thus the laser) on M106 to 100% for a fraction of a second before going to the intended Sxx value, if the fan was off before. So I must avoid turning the laser off with M107, instead I need to send M106 S1.
It would really be great if I could set this in the machine settings when using a “Marlin” based device.
Workaround: Create a “Custom GCode” device, there I can set the required settings which brings me further, but then I run into another problem:
LB doesn’t evaluate the answer to an M114 correctly, thus the shown coordinates in the move tab always stay 0. I can consequently jog XYZ in one direction, but not backwards.
Console shows “X:60.00 Y:70.00 Z:0.15 E:0.00 Count X: 60.00 Y:70.00 Z:0.15 E:0.00” when I click the button to get the current position, but the position shown stays X 0 Y 0 Z 0 U 0 :frowning:
Can somebody help me getting my laser to work?
Details about my setup, tell me if any additional info required:
  • Neje E40 on Prusa MK3S+ with FW 3.14.1
  • Laser connected to part-fan of the printer (thus M106 to steer the PWM)
  • LB 2.0.02 on MacOS, Connected via USB
If you use the previous LightBurn version: 1.7.08, do the M114 coordinates come through into the Move Window properly? (I’ve had a couple of reports now that 2.0 has broken something with the M114 ‘Get Position’ values not being read into LightBurn Move Window as they previously did).
Yes, that part worked in 1.7
Can you check the device setting in LB 2.0.02 ? From the main menu, choose Laser Tools→Device Settings, then turn on the Machine coordinates option and exit. I reproduced the problem with my Marlin device, and this fixed it.
