I run my OMTech China Blue with the door open at least an inch to allow intake air flow. I’ve run it with no panels at all and quite frequently in this configuration.
I believe most people think of a focused laser as a tiny, high energy emf reflecting as a tiny emf field.
Simple fact is what makes a laser useful, is the lens, it takes a relatively low power emf field and focuses it to a tiny spot, putting all that energy into a very small area. Even more simply, after passing through a lens, after the convergence point, the beam diverges greatly and quickly looses power. Anyone that’s used a machine out of focus knows how critical focus is.
If you are 3 feet away, it would be like focusing 3 feet past the focal point, meaning all of that energy is dispersed over a much large area. You don’t get a focused spot or beam when it’s reflected, you get the same divergence over distance that you get on the machines lens.
The most safe operation occurs if you understand how the machine works. Chances of reflections out of my China Blue could only occur is if one of the mirrors fell out at the exact angle to reflect it out of the machine. This isn’t the machines fault or a safety issue directly.
Another point, is that hundreds of thousands, if not millions of these machines are out there operated by people with an IQ of less than a bag of rocks, how many of these have been blinded or damaged vision? I’ve never read about anything that makes sense like this occurring. There’s probably more led lasers out there with the low cost safety goggles supplied with the machine. These must work or we’d heard about people with seeing difficulties.
I use the supplied safety glasses on my fiber as it’s all open. However when I find videos of people using 1.5kW or larger fiber rust remover without any kind of safety glasses, I wonder how much truth this safety protection holds true. This is especially true when I can’t lase baloney, bread or hot dogs.
Understand how they work and use common sense around them. I wear safety glasses doing most work, stuff ends up hitting the glasses, so I’m an advocate of safety glasses.
This is not a recommendation to look from m3 back to m2 and the tube with your remaining eye.
