Hi. I’m new here and have used my 30 day trial. Can someone tell me which software I buy? I assume as everything worked fine I just purchase the g code one at 40 dollars? thanks. Peter
What type of controller is in your laser? Your profile says you have a 1390 laser which is quite large and generally comes with a DSP controller. If that is the case you need the $80 DSP version.
Hi I have a rudia controller
Then you need the DSP version.
thank you for your reply
