Putting a PAUSE in the LightBurn Flie
I have parts I want to etch both side of. Is it possible to put a pause in the program, so the laser will stop, I can open it up, reposition the part, close it, and then proceed to etch the other side?
Patrick
I think the best solution would be to split the task in two. But you can also assign the front and back their own layers and enable / disable the layers respectively after you have turned your subject
Thanks - I thought of that, but hoping for a simple solution - like an M00 in G-Code for CNC.
Patrick
