PWM spindle is not enabled
I updated the firmware of the MKS DLC32 controller to the latest version of (V2.30_H35_2022_1223_N_ZX_001), after that I pressed the “spindle” option on the touch-screen attached to the controller. Then, when I try to engrave/cut with the laser, there’s no more laser coming out and I got this error ([MSG:M4 requires laser mode or a reversable spindle]
error:20
Unsupported or invalid g-code command found in block.
On or near line 2:).
I tried to figure it out by myself, I set the PWM frequency to 1kHz and I got this message ([MSG:PWM spindle Output:GPIO(32), Enbl:None, Dir:None, Freq:1000Hz, Res:16bits]), where I noticed that Enbl and Dir are not defined.
So how can I fix it up if any one can help please.
please note that the laser is working when I try to frame any shape.
You probably didn’t set $32=1 That might create the first error.
You should only set the PWM frequency yourself if you know that your laser head has a specific one.
I suggest resetting the firmware settings and set $32=1. Then try again.
It’s is already on, check the following settings
$0=10
$1=25
$2=0
$3=1
$4=0
$5=1
$6=1
$46=10.000
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=1
$24=300.000
$25=1000.000
$26=250.000
$27=1.000
$28=1000.000
$30=10000.000
$31=0.000
$32=1
$38=0
$40=1
$100=80.000
$101=80.000
$102=80.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=6000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=450.000
$131=450.000
$132=50.000
$133=300.000
$134=300.000
$135=300.000
ok
One of the reasons you get no beam is because $30 is set to 10,000. Set it to 1,000. Usually, most control software use 1000 as a maximum s-value.
Also, make sure you didn’t enable gcode clustering in the device settings. Though I don’t think that’s the issue here.
Maybe also try to go one firmware version back, I think I read a few reports that the latest version has some bugs. But I don’t recall exactly.
