Quality for small engraving not acceptable
Hello
I have a problem with the small fine engravings on Lightburn.
I had been using my usual software for years.
For 1 month, I have been using Lightburn and I find that the engraving of small elements such as text is messy, much less fine.
Here are 2 examples, the settings are exactly the same, the wood is the same, the visual is the same, nothing has been touched on the engraver.
Fill mode:
Max: 40
Minimum: 35
Speed: 600
Interval between the lines: 0.05
Do you know how to fix this problem?
I have a lot of keychains and wooden pendants to make, and the result is really not pretty.
What are the units for these values?
A few additional questions:
  1. What is the usual software that you’re using? If this is on a Ruida I assume it’s RD Works but would like to confirm. The engraving characteristics make me question this though.
  2. the LightBurn examples almost look out of focus. How is focus achieved on your laser? Is it the same for both LightBurn and your current software?
  3. What is the source of the design? And are the textual elements paths, bitmaps, or retained as text in your designs?
  4. Can you upload the designs in original format (you may need to change the file extension to .txt to do this) and .lbrn format for comparison?
I think it’s a scan offset issue.
These are adjusted in the device settings.
Hello,
Yes my usual software is RD WORKS.
It is not about importing a file but text, therefore written directly on the software: these are paths.
That said, the result is the same when I import a png or bmp file.
Focus ? No idea, I didn’t touch anything (the engravings were made at the same time, 30 seconds apart), it’s done automatically by the machine when I turn it on.
So the machine adjusts for focus depending on material thickness automatically on machine start?
I ask because unless the photos are blurry the burns don’t have as crisp of an edge as I would expect.
In any case, I suspect @jkwilborn is correct that the core issue is related to offset scanning adjustment. You can confirm by burning a filled rectangle with bidirectional scanning and a larger line interval, something like 1 mm. If the edges of the burn are not aligned it could create the discrepancy you see.
Hello,
Here is a test with a rectangle 1cm high x 2cm wide.
Then the word test.
On the left, this is Lightburn, on the right this is RD workds.
Engraving done without modifying anything, same settings, same plate.
Sorry, I am French and I don’t understand everything from this docs :sweat_smile: This is technical language
Can you increase the line interval (Intervalle entre les lignes) to something higher? Set to 1 or 2 mm instead of 0.1 mm as it is now. This will allow you to see if the lines going left to right and right to left match up.
@berainlb wishes to see, is the scan lines to be further apart so we can see it clearly.
When you run it next time, with a lower lines/inch (lpi/dpi) you can see each scan line and how it lines up…
Is Lightburn in image mode?
In image mode ? I don’t know. I have lightburn since around 1 month. I have’nt changed the basic seetings.
With 2 mm
And 1 mm
The shape is 40mm x 27 mm, is it enough ?
Yes. You can see that there is a very small variance along the left and right edges of the lines.
You could run the same test in RD Works to confirm the issue doesn’t exist there.
If that’s the case then you could use the Scanning Offset Adjustment in Device Settings to correct for this.
More information on how that works here:
Scanning Offset Adjustment - LightBurn Software Documentation
With RD WORKS :
That looks improved from LightBurn but not perfect. If you make the corrections for Offset Scanning Adjustment you may be able to improve on what you’re currently getting with RD Works.
In either case, it confirms the diagnosis.
I followed the tutorial in the link, I engraved the square 1mm apart, at several speeds.
But the line gaps are infirm, it’s impossible for me to measure, it’s not even 0.5 millimeters !
How am I supposed to fix this problem then ?
I’d suggest then doing a trial and error method. Make a small adjustment and do a visual confirmation to see how that adjustment affected the output. Adjust higher if inadequate or go back if you’ve gone too far. Once things look good visually then you’re good to go.
By the way this ling does’nt work : http://cartonus.com/how-to-improve-engraving-quality-of-laser-machine/
What is that link from?
