hola , pregunto ,dentro de unos dias se me vence la prueba gratuita , y tengo que comprar la licencia cual me recomiendan que no sea cara , gracias
There’s only two choices.
- To connect to a GCode-based laser, you’ll need a LightBurn Core license.
- To connect to a DSP or Galvo laser, you’ll need a LightBurn Pro license. LightBurn Pro licenses also support GCode-based lasers.
If you start with the core license and decide you want to use different lasers,
you can then simple do an upgrade to the pro license.
For additional information please see:
HTH. ![]()
gracias compre la lightburn core ,y muchas gracias por tu informacion
