This could be normal, but it may be that I am just doing something wrong. When I bring in an image with the intent of inverting the image to burning black paint off a white tile I go into Adjust Image, click invert, close the window, and my image on the Lightburn screen doesn’t look inverted. However, when I burn it, the inverse does work. Is it normal that the Lightburn screen will not reflect that inverse and you just have to know it’s checked?
The setting i am choosing is “negative image”
Yes, that is normal behavior. It should show inverted in the preview window though… but you have to uncheck invert in the preview. I don’t understand why, just how it is.
Thank you for confirming. I will just be careful to be sure the setting is the way I want it.
