I got my first laser Atomstack x20 a few days ago…and I noticed that It is very noisy and smells not good…So I’d like to connection via wifi because doing job from a distance…
I tried to connect via Tibbo Vitual port, but when I command to frame, good job and It is start and then stops working in the actual work command…just Busy displayed and then stop.
How can I connecting via to wifi?
Thank you…
We emphatically assert that you should not operate your laser at a significant distance or remotely. Use ventilation and exhaust fans or equipment to manage the smoke and the smell. Lasers make fire.
It seems possible that the Tibbo Virtual port is not relaying the state of the buffer back to LightBurn.
There is a great deal to configure on the Tibbo Virtual Port. They make several products. Which one did you choose?
You may have success adjusting these parameters in LightBurn to match your communication parameters.
Thanks for reply…It helped me a lot.
