Question more related to the D1
Is it possible to have the rotary tool work in Y axis? Reason I am asking is I would like to engrave on cork fishing handles already on the rod. So obviously they are going to stick out well beyond the machine. There isn’t roomto set the pole the other way. My only thought was to turn the machine 90 degrees but was hoping for a better answer.
If you can plug it in, you could try it.
I also recommend that you find a chunk of broom handle the same diameter as the cork handle to get the rotary set up.
Don’t waste good cork handles on machine settings. :smiley:
Thanks, I bought a wooden dowel for practice.
