I cannot for the life of me get any setting as to size of radius to work in any of these corners. Yesterday I had them all working. I increased size of drawing so I could see openings if that had anything to do with my problem. I want the end to far right to be rounded full width and all other corners to be rounded 6.4mm radius. I am hoping that having passed my ninety second birthday, this stupidity hasn’t locked on for the duration.
Marion, just throw your shape up here as lbrn2, that makes it easier.
But as I see it, the shape is big enough to handle Ø6.4.
If we have misunderstood, please explain it again
Your individual lines do not connect and many have curves to them as well. Probably not what you intended. Make 2 overlapping boxes, then select both and use the Weld function. Once it’s a single shape you will be able to radius the corners.
