Radius, it doesn't work for me anymore
I’ve never had problems with any update, but with 1.4.05 I can’t round the corners with the appropriate command with any value, whether positive or negative.
Does it only happen to me?
… No problems here with my Mac version. You can back roll update, just install the last functioning version over the existing version if it is important to be able to work with this radius feature.
Make sure that you have a connected shape of straight lines, or 2 more more straight lines that are connected. LB cannot blend a radius between unconnected straight lines, or between a radius and a straight line, or two radius lines. You will be able to do it in the upcoming 1.5 release
Since you said “it”, are you only going to be able to do the one or all three? That will be nice either way.
@LightBurn said in a previous post that you would be able to do all three.
Ok, I was stupid, I forgot to select the angle. Sometimes age plays tricks on you! :slight_smile:
