Hello! Gweike G2 20w fiber.
Was having an issue with larger squares being curved. Have imported config settings for lens correction.
I ran the galvo 9 point correction and it fixed the rounded square issue flawlessly! However, upon running a file with circular pattern, the circles are now squished ovals (shrunk across the Y). The dimensions should be 79.2mm circle but it measures 82mm tall, 92(??) Wide.
I am attaching what I hope are relevant images.
If you create a new device and do a manual setup first?
I re input the lens parameters from the manufacturer and everything was fixed. Are these values getting removed or changed somehow?
The settings usually get attached to each device.
