Am I able to have multiple images on Lightburn screen and only use one to vector with out it selecting all?
look at the Cut tab( to the left of MOVE tab ) and you’ll see check boxes next to your layers. If you only have one layer, select one of your images and then click on a color across the bottom of the Lightburn window and you’ll get a new layer. Now you can define what you want that layer to do. ie power/speed and even enable/disable output and visibility in the display.
I don’t understand the question - can you re-word it? It’s not clear what you’re trying to do.
