Raytools XC3000S Series Fiber Laser Controller
Hello, I would like to use Lightburn on a Raytools XC3000S Series Fiber Laser Controller
What kind of controller does it use? That determines if Lightburn will be usable. It’s always nice to have a link to the product…?
If it can run EZCad2 then it will run Lightburn…
However, if it runs EZCad3 or some other type of propitiatory software, you’re out of luck.
The only other option is to change out the control board to something that does support Lightburn…
Found this link to it… it does say this about gcode, don’t know exactly what it means, but it may run off some variation of gcode???
Compatible to processing by manual G code modification
Might want to hear from @Rick over this…
Good luck
