For your information:
with the RC-3 version, closing a dialog box causes LB to crash.
(Mac Mini M1)
Can you provide the crash report you get?
I have several crash reports (RC3 and RC4), which would you like?
PS: I don’t know how to send a private message.
The most recent, RC4 one please.
You can upload it here to the thread by dragging the file in the message box.
LB RC3 crash 24_09_04 15_31.txt (86,6 Ko)
LB RC3 crash 24_09_04 15_52.txt (100,4 Ko)
LB RC4 crash 24_09_05 08_25.txt (97,7 Ko)
LB RC4 crash 24_09_05 08_38.txt (104,6 Ko)
Hi Adnet
To make things a little neater - Split this issue into a New Topic.
Was trying to replicate this crash behaviour.
I also have a MacMini just like yours
Could you provide a step by step replication from Opening LigthBurn to the crash please?
Hello, Gilaraujo
- j’ai installé la RC3 qui s’est bloquée durant des essais de dessin (avec de lignes courbes). L’application ne répondait plus. Je l’ai forcé à quitter via le menu Apple.
- en ouvrant à nouveau l’application, un pop-up m’indique que le dernier document n’a pas été sauvegardé proprement (normal, suite à l’arrêt forcé).
- lorsque je veux fermer ce pop-up, soit en cliquant sur No, Yes ou le bouton rouge, LB crash directement.
je ne sais pas en dire plus.
- I installed RC3, which crashed when I was trying to draw (with curved lines). The application stopped responding. I forced it to quit via the Apple menu.
- when I open the application again, a pop-up tells me that the last document hasn’t been saved properly (normal, following the forced shutdown).
- when I try to close this pop-up, either by clicking on “No”, “Yes” or the red button, LB crashes directly.
I can’t say any more.
Thank you very much will try to replicate!
I was able to replicate the dialog box by force quitting LightBurn after the 1st auto save.
However, not able yet to replicate the crash on the buttons while on RC4
WIll go back to RC3 and test again
I also tried on my M1 Mini, and wasn’t able to cause the crash (RC3).
Hello Adnet
Could you try to install RC6 build to confirm if the issue persist for you?
https://release.lightburnsoftware.com/LightBurn/RC/LightBurn-v1.7.00-RC-6/
I tested with RC10 after completely uninstalling LB and LB_RC (with CleanMyMac).
The problem remains ![]()
If I open the import of a machine, when closing the box, LB crashes.
(import of the setting made under LB 1.6.03)
Does this happen if you use Language English?
hehe … no problem in English
Interesting.
Reporting thank you.
