RC7, Epilog Fusion Pro48
When setting up for a vector cut, the layer settings don’t let me set the speed greater than 300in/min. I should be able to set the speed to 9921in/min which is 100% speed.
Hello Dan
The Specifications on the Epilog Fusion Pro are 4200mm/sec or 165 in/sec
So the 9921in/min should be possible on the UI, Inquiring internally.
Hello Dan
There seems to be for sure something going on between the cut/layer Panel Speed (in/min) and the internal Cut/Layers Editor Input.
Thank you for bringing this up.
Investigating
Small Update @DanLand
Dev team found the issue and should be patched for the next RC Build.
Thank you again
Sounds good, thank you.
